Wake from hibernation - BSOD - several stop codes - hardware issue?
Diskutiere Wake from hibernation - BSOD - several stop codes - hardware issue? im Windows 10 Forum im Bereich Microsoft Community Fragen; Hi community! I hope someone can point me to the right direction. I'm tracking down a computer problem which existed for quiet a long time on...
Hi community!
I hope someone can point me to the right direction. I'm tracking down a computer problem which existed for quiet a long time on this machine. This is my last approch to solve it.
The issue:
1. the computer is put into hibernation (this kind of hibernation: "powercfg.exe /hibernate on", hybride sleep: off).
2. when I wake up the computer after around 6 minutes, I get a BSOD, the stop codes vary from blue screen to blue screen
What I found out so far:
- when hibernation period is shorter then 6 minutes, everything is fine
- computer is running stable once booted, no BSOD during work time, even on heavy load
- when PSU is switched off during hibernation (and hibernation period is under 6 minutes) BSOD occure on wake up
- clean boot after shutdown is randomly affected, too
- plug-in boot drive to another SATA port has no affect
- resetting bios has no affect
BSOD stop codes I gathered so far:
0x000000fc (0xffff848c92aa6000, 0x8a00000608a008e3, 0xfffffe8a10059b90, 0x0000000000000003) >> ATTEMPTED_EXECUTE_OF_NOEXECUTE_MEMORY
0x00000050 (0xfffff8041d0c3590, 0x0000000000000010, 0xfffff8041d0c3590, 0x0000000000000002) >> PAGE_FAULT_IN_NONPAGED_AREA
0x00000139 (0x0000000000000003, 0xfffff08d598ca8a0, 0xfffff08d598ca7f8, 0x0000000000000000) >> KERNEL_SECURITY_CHECK_FAILURE
0x0000004e (0x0000000000000099, 0x0000000000152945, 0x0000000000000001, 0x0000000000000000) >> PFN_LIST_CORRUPT
0x0000001a (0x000000000000**** 0xfffff00506459cf0) >> SYSTEM_THREAD_EXCEPTION_NOT_HANDLED
0x00000021 (0x0000000000000000, 0x0000000000000001, 0x0000000080000400, 0x000000007d314c30) >> QUOTA_UNDERFLOW
0x00000050 (0xffffd6ffec6fb647, 0x0000000000000000, 0xfffff806483b5a91, 0x0000000000000002) >> PAGE_FAULT_IN_NONPAGED_AREA
0x0000003b (0x00000000c0000005, 0xfffffc1e49b031ba, 0xffffef88adb33970, 0x0000000000000000) >> SYSTEM_SERVICE_EXCEPTION
On BSOD a memory.dmp is generated. I opened it with WinDbg Preview, but I'm not really understanding, what is going on there or how to interprete the results (I hoped it points to a .dll or device, but all I see are registers, memory addresses and assembler code).
0x00000139 >> KERNEL_SECURITY_CHECK_FAILURE seems to occure more often then the others - 3 times so far.
System information:
- Windows 10 Pro 17763 (freshly installed two weeks ago)
- Gigabyte H77-D3H (latest Bios**** found nothing)
- be quiet! Straigth Power BOT E9 400W
- everything is unplugged from mainboard for trouble shooting, except SSD, CPU, RAM, 2 Fans, power
Suspicion:
I think the issue is related to power supply. The time periode, which seems to decide between successful or faulty wake, reminds me of a discharging capacitor on PSU or Mainboard. However, as far as I know, Windows hibernation is independend from power supply, so I'm not sure and posting this issue here.
Help!
- Can someone tell me more in detail about the stop codes - I know about the Microsoft Bug Check Code Reference, but I'm not programmer enough, to fully understand or use thisfor troubleshooting
- Can someone tell me how to use and interprete the memory.dmp files in order to find the faulty piece of driver or hardware, if even possible
!!Any tipps, references, knowledge, experiences or ideas to troubleshoot this are highly appreciated!!
Thank you in advance,
Martin
Wake from hibernation - BSOD - several stop codes - hardware issue? - Ähnliche Themen
iPhone to PC photo transfer via USB stops after seconds: Hi there, I have a brand new, clean install Windows 10 64bit PC and an iPhone. When I connect the phone to the PC, after some seconds I see the...
Searching in the Windows Menu: My problem is that the searching function is completely disabled. So I also already started this problem finding program, it said "Searching is...
I am interested in triggering a BSOD with user-defined values: What I found on the internet suggests that all error codes are hard-coded, my question now is, could I edit them or edit only one, namely the...
Windows update on October 20, 2020: Yesterday evening was an update on Windows. When I logged on today I had no more access to my NAS server. I spent the day trying to find out what...
Blue screen: Hello. I have a big problem with my computer, I have it for 3-4 months and everything was ok until yesterday. suddenly a blue screen with various...
