Threadripper 1950x & ASUS Zenith Extreme - DistributedCOM Error causes system crashes.
Diskutiere Threadripper 1950x & ASUS Zenith Extreme - DistributedCOM Error causes system crashes. im Windows 10 Forum im Bereich Microsoft Community Fragen; Hi, I am having issues with my pc and I can't seem to fix them. It frequently gets DistributedCOM crashes. Event Viewer reports this: Durch...
Hi,
Durch die Berechtigungseinstellungen für "Anwendungsspezifisch" wird dem Benutzer "MASTERSTRIKE\chris" (SID: S-1-5-21-2088241240-3813939689-2065293475-1001) unter der Adresse "LocalHost (unter Verwendung von LRPC)" keine Berechtigung vom Typ "Lokal Aktivierung" für die COM-Serveranwendung mit der CLSID
{2593F8B9-4EAF-457C-B68A-50F6B8EA6B54}
und der APPID
{15C20B67-12E7-4BB6-92BB-7AFF07997402}
im Anwendungscontainer "Nicht verfügbar" (SID: Nicht verfügbar) gewährt. Die Sicherheitsberechtigung kann mit dem Verwaltungstool für Komponentendienste geändert werden.
I should be having the latest driver for any devices in my PC, but 2 devices are showing up with warnings in Device Manager. However, both of them are not used by me, so if they cause the error. I can uninstall one of the since they are the Ethernet Network Card that I don't use. The other one is the pesky WiFi 5 Ghz module in my Motherboard which can't be removed physically. The for that device are beta drivers provided by ASUS and they are terrible so I never bothered installing them. My BootCKCL.etl is also relatively large with 100 Mb sizes at times.
Threadripper 1950x & ASUS Zenith Extreme - DistributedCOM Error causes system crashes. - Ähnliche Themen
Android Emulator Causes Windows 10 Crash and goes to BSOD: Hi, I have a problem with running Android Emulator in my Visual Studio. I am using Visual Studio 2019 and I have created just a blank simple...
Headset not working fine with Windows: Hi everyone I have in general a problem with my Headsets that are connected to my Headset. I can connect the headset to windows an i can hear...
I am interested in triggering a BSOD with user-defined values: What I found on the internet suggests that all error codes are hard-coded, my question now is, could I edit them or edit only one, namely the...
iPhone to PC photo transfer via USB stops after seconds: Hi there, I have a brand new, clean install Windows 10 64bit PC and an iPhone. When I connect the phone to the PC, after some seconds I see the...
Windows Store gone, can´t reinstall?? / Windows Store verschwunden, kann nicht neu installieren??: For some reason my Microsoft Store has disapeared and I can´t even find the parts of it, that are supposed to be reset/whatever on my System...
