Fields in MS Word: Create a partial TOC from another document using bookmarks and the RD field
Diskutiere Fields in MS Word: Create a partial TOC from another document using bookmarks and the RD field im Office Forum im Bereich Microsoft Community Fragen; Hi everybody, Image two cases: (1) If I would want to compile a partial TOC just for a section, I would create a bookmark for this entire...
Hi everybody,
Image two cases:
(1) If I would want to compile a partial TOC just for a section, I would create a bookmark for this entire section and then use a \b switch after the TOC field, adding the name of this bookmark.
(2) If I would want to compile a TOC derived from the content of document A in document B, I would add a TOC field in document B, and directly afterwards add an RD field with the filename of document A.
Both solutions work perfectly.
(3) Now I want to have a partial TOC of a section of document A in document B. I add a bookmark for the respective section in document A. Then I add a TOC field in document B using a \b switch with the name of the bookmark in document A. And then finally I add an RD field right under the TOC field in document B.
{ TOC \b Chapter1 }
{ RD "writing-template.docx" \f }
However, in this case, it tells my that the bookmark has not been defined. It looks like, Word is somehow not capable of passing on bookmarks using the RD command? Is that correct?
Any idea on how to fix this? Any workaround to create partial TOCs across documents?
Fields in MS Word: Create a partial TOC from another document using bookmarks and the RD field - Ähnliche Themen
STOP Word from Updating Date&Time automatically every document: Hello Is there a solution (via Macro or so) to stop word from updating the date and time fields when opening a document. I want a solution for...
Copying a SharePoint online document library to another site: Hi Everyone! We have two sites in SharePoint online and want to copy the content of a document library (~1TB) into the library of the other...
WORD MACRO: Search for date fields and replace result: Hi I'm working on a solution to search date fields in Word and replace the result. Replacing the result should be easy but how can I search for...
Word independently opened a tab in Chrome: I've been working a document while simultaneously having some tabs open on Chrome. None of the tabs on chrome had anything to do with the...
Word independently opened a tab in Chrom: I've been working a document while simultaneously having some tabs open on Chrome. None of the tabs on chrome had anything to do with the...
