BSOD SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M (1000007e)
Diskutiere BSOD SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M (1000007e) im Windows 10 Forum im Bereich Microsoft Community Fragen; SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M (1000007e) This is a very common bugcheck. Usually the exception address pinpoints the driver/function that...
  • BSOD SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M (1000007e) Beitrag #1
the driver/function that caused the problem. Always note this address
as well as the link date of the driver/image that contains this address.
Some common problems are exception code 0x80000003. This means a hard
coded breakpoint or assertion was hit, but this system was booted
/NODEBUG. This is not supposed to happen as developers should never have
hardcoded breakpoints in retail code, but ...
If this happens, make sure a debugger gets connected, and the
system is booted /DEBUG. This will let us see why this breakpoint is
happening.
Arguments:
Arg1: ffffffffc0000005, The exception code that was not handled
Arg2: fffff8026b63a319, The address that the exception occurred at
Arg3: ffffec8a368c71a8, Exception Record Address
Arg4: ffffec8a368c69f0, Context Record Address
Debugging Details:
*** WARNING: Unable to verify checksum for win32k.sys
KEY_VALUES_STRING: 1
Key : AV.Fault
Value: Read
Key : Analysis.CPU.Sec
Value: 3
Key : Analysis.DebugAnalysisProvider.CPP
Value: Create: 8007007e on DESKTOP-DEQQ9CP
Key : Analysis.DebugData
Value: CreateObject
Key : Analysis.DebugModel
Value: CreateObject
Key : Analysis.Elapsed.Sec
Value: 27
Key : Analysis.Memory.CommitPeak.Mb
Value: 73
Key : Analysis.System
Value: CreateObject
ADDITIONAL_XML: 1
BUGCHECK_CODE: 7e
BUGCHECK_P1: ffffffffc0000005
BUGCHECK_P2: fffff8026b63a319
BUGCHECK_P3: ffffec8a368c71a8
BUGCHECK_P4: ffffec8a368c69f0
EXCEPTION_RECORD: ffffec8a368c71a8 --
(.exr 0xffffec8a368c71a8)
ExceptionAddress: fffff8026b63a319 (nt!FsRtlAcquireHeaderMutex+0x0000000000000039)
ExceptionCode: c0000005 (Access violation)
ExceptionFlags: 00000000
NumberParameters: 2
Parameter[0]: 0000000000000000
Parameter[1]: ffffffffffffffff
Attempt to read from address ffffffffffffffff
CONTEXT: ffffec8a368c69f0 --
(.cxr 0xffffec8a368c69f0)
rax=0000000000000001 rbx=ffffc8879b18e360 rcx=ffffc8879b18e040
rdx=d05ca2f200109a00 rsi=0000000000000000 rdi=d05ca2f200109a00
rip=fffff8026b63a319 rsp=ffffec8a368c73e0 rbp=fffff8026de05450
r8=ffffec8a368c73f8 r9=7fffc887940b74b0 r10=fffff8026b63a2e0
r11=ffffec8a368c73e0 r12=0000000000000000 r13=0000000000000000
r14=ffffec8a368c7501 r15=ffffd90878143a40
iopl=0 nv up ei ng nz na pe nc
cs=0010 ss=0018 ds=002b es=002b fs=0053 gs=002b efl=00050282
nt!FsRtlAcquireHeaderMutex+0x39:
fffff802`6b63a319 f00fba3700 lock btr dword ptr [rdi],0 ds:002b:d05ca2f2`00109a00=????????
Resetting default scope
BLACKBOXBSD: 1 (
!blackboxbsd)
BLACKBOXNTFS: 1 (
!blackboxntfs)
BLACKBOXPNP: 1 (
!blackboxpnp)
BLACKBOXWINLOGON: 1
CUSTOMER_CRASH_COUNT: 1
PROCESS_NAME: System
READ_ADDRESS: fffff8026bb733b8: Unable to get MiVisibleState
Unable to get NonPagedPoolStart
Unable to get NonPagedPoolEnd
Unable to get PagedPoolStart
Unable to get PagedPoolEnd
fffff8026ba2a3c8: Unable to get Flags value from nt!KdVersionBlock
unable to get nt!MmSpecialPagesInUse
ffffffffffffffff
ERROR_CODE: (NTSTATUS) 0xc0000005 - The instruction at 0x%p referenced memory at 0x%p. The memory could not be %s.
EXCEPTION_CODE_STR: c0000005
EXCEPTION_PARAMETER1: 0000000000000000
EXCEPTION_PARAMETER2: ffffffffffffffff
EXCEPTION_STR: 0xc0000005
STACK_TEXT:
ffffec8a`368c73e0 fffff802`6dcd440a : ffffd908`7a266498 ffffd908`78143ad0 ffffd908`7a266050 ffffd908`000000ff : nt!FsRtlAcquireHeaderMutex+0x39
ffffec8a`368c7410 fffff802`6ddaf4fe : ffffec8a`368c77f0 ffffc887`940b6180 ffffd908`7a266050 ffffd908`7a266498 : Ntfs!NtfsTeardownFromLcb+0x16a
ffffec8a`368c74b0 fffff802`6dcd892a : ffffec8a`368c77f0 ffffec8a`368c75b1 ffffd908`7a266498 ffffec8a`368c77f0 : Ntfs!NtfsTeardownStructures+0xee
ffffec8a`368c7530 fffff802`6ddd0cec : ffffec8a`368c7600 ffffd908`00000000 ffffec8a`00000000 ffffec8a`368c77f0 : Ntfs!NtfsDecrementCloseCounts+0xaa
ffffec8a`368c7570 fffff802`6ddcfc31 : ffffec8a`368c77f0 ffffd908`7a2661b0 ffffd908`7a266050 ffffc887`940b6180 : Ntfs!NtfsCommonClose+0x45c
ffffec8a`368c7650 fffff802`6de054d8 : 00000000`0000001c fffff802`6bb8f240 00000000`00000000 00000000`00000000 : Ntfs!NtfsFspCloseInternal+0x241
ffffec8a`368c77b0 fffff802`6b6bd095 : ffffc887`8ec47970 ffffc887`9b18e000 fffff802`6b6f7800 ffffc887`8ec47970 : Ntfs!NtfsFspClose+0x88
ffffec8a`368c7a70 fffff802`6b72a7a5 : ffffc887`9b18e040 00000000`00000080 ffffc887`8ec6c040 000024ef`b59bbfff : nt!ExpWorkerThread+0x105
ffffec8a`368c7b10 fffff802`6b7c8b2a : fffff802`66e87180 ffffc887`9b18e040 fffff802`6b72a750 0006ef80`00000000 : nt!PspSystemThreadStartup+0x55
ffffec8a`368c7b60 00000000`00000000 : ffffec8a`368c8000 ffffec8a`368c1000 00000000`00000000 00000000`00000000 : nt!KiStartSystemThread+0x2a
SYMBOL_NAME: nt!FsRtlAcquireHeaderMutex+39
MODULE_NAME:
nt
IMAGE_NAME: ntkrnlmp.exe
IMAGE_VERSION: 10.0.18362.535
STACK_COMMAND: .cxr 0xffffec8a368c69f0 ; kb
BUCKET_ID_FUNC_OFFSET: 39
FAILURE_BUCKET_ID: AV_nt!FsRtlAcquireHeaderMutex
OS_VERSION: 10.0.18362.1
BUILDLAB_STR: 19h1_release
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
FAILURE_ID_HASH: {68e5700a-5d25-fc1f-47ba-91e2a2183ad1}
Followup: MachineOwner
BSOD SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M (1000007e) - Ähnliche Themen
Bluescreens: Hallo erstmal :) Habe Probleme mit regelmäßigen Bluscreens und zwar fing es vor einigen Wochen an. in der Zwichenzeit habe ich bspw nun auch...
Pc stürzt bei spielen ab: Guten Tag, Ich habe ungefähr vor 2 Wochen meinen Pc neu uns sauber aufgesetzt. Allerdings stürzt mein Pc bei Spielen mit mehr Leistung immer...
Nach Crash die Minidump File ausgelesen; was ist das Problem?: Ich hatte vor kurzen einen System Service Exeption Bluescreen, dabei habe ich die Crash File versucht auszulesen, aber selbst komme ich nicht...
BSOD bei vermeintlichem Treiberfehler (seit Jan 2020) verursacht durch ndis.sys+79ccb: Seit Jan 2020 bekomme ich häufig eine BSOD zu sehen. Neuere Netzwerktreiber lassen sich nicht installieren. Windows 10 sagt der aktuelle Treiber...
Mehrere Blue Screens nach Neuinstallation: Hallo Zusammen, ich habe mir neulich einen neuen Rechner zusammengebaut. Verbaut ist: AMD Ryzen 5 2600 6x 3.40GHz So.AM4 BOX 16GB (2x...
revel casino
casino games free
poker com
Npoker com
, chukchansi casino, chukchansi Ecasino, lake tahoe casinos, lake tahoe casiTnos, poker dogs, rpoker dogs, best online casino, best online casEino, free poker tournaments, vip p(oker, free puoker games download, video pokqer free, promo code doubledown casino, promo code doubledown cSasino, world poker tour, world Ppoker tour, kiowa casino, zeus poker, zeus wpoker, mt airy cPasino, mid states pok[er tour
