Blackscreen beim zocken
Diskutiere Blackscreen beim zocken im Windows 10 Forum im Bereich Microsoft Community Fragen; Hallo, wie oben schon erwähnt wird beim zocken mein monitor schwarz und der pc startet neu. Bei WinDbg kam das raus: Microsoft (R) Windows...
Microsoft (R) Windows Debugger Version 10.0.19528.1000 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\MEMORY.DMP]
Kernel Bitmap Dump File: Kernel address space is available, User address space may not be available.
************* Path validation summary **************
Response Time (ms) Location
Deferred srv*
Symbol search path is: srv*
Executable search path is:
Windows 10 Kernel Version 19041 MP (8 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
19041.1.amd64fre.vb_release.191206-1406
Machine Name:
Kernel base = 0xfffff801`7f200000 PsLoadedModuleList = 0xfffff801`7fe2a2b0
Debug session time: Sun Jun 21 22:41:30.055 2020 (UTC + 2:00)
System Uptime: 0 days 1:11:44.734
Loading Kernel Symbols
......Page 1f1248 not present in the dump file. Type ".hh dbgerr004" for details
Loading User Symbols
Loading unloaded module list
For analysis of this file, run
!analyze -v
nt!KeBugCheckEx:
fffff801`7f5dda20 48894c2408 mov qword ptr [rsp+8],rcx ss:0018:fffff40a`87195830=0000000000000116
NatVis script unloaded from 'C:\Program Files\WindowsApps\Microsoft.WinDbg_1.2001.2001.0_neutral__8wekyb3d8bbwe\amd64\Visualizers\atlmfc.natvis'
NatVis script unloaded from 'C:\Program Files\WindowsApps\Microsoft.WinDbg_1.2001.2001.0_neutral__8wekyb3d8bbwe\amd64\Visualizers\concurrency.natvis'
NatVis script unloaded from 'C:\Program Files\WindowsApps\Microsoft.WinDbg_1.2001.2001.0_neutral__8wekyb3d8bbwe\amd64\Visualizers\cpp_rest.natvis'
NatVis script unloaded from 'C:\Program Files\WindowsApps\Microsoft.WinDbg_1.2001.2001.0_neutral__8wekyb3d8bbwe\amd64\Visualizers\stl.natvis'
NatVis script unloaded from 'C:\Program Files\WindowsApps\Microsoft.WinDbg_1.2001.2001.0_neutral__8wekyb3d8bbwe\amd64\Visualizers\Windows.Data.Json.natvis'
NatVis script unloaded from 'C:\Program Files\WindowsApps\Microsoft.WinDbg_1.2001.2001.0_neutral__8wekyb3d8bbwe\amd64\Visualizers\Windows.Devices.Geolocation.natvis'
NatVis script unloaded from 'C:\Program Files\WindowsApps\Microsoft.WinDbg_1.2001.2001.0_neutral__8wekyb3d8bbwe\amd64\Visualizers\Windows.Devices.Sensors.natvis'
NatVis script unloaded from 'C:\Program Files\WindowsApps\Microsoft.WinDbg_1.2001.2001.0_neutral__8wekyb3d8bbwe\amd64\Visualizers\Windows.Media.natvis'
NatVis script unloaded from 'C:\Program Files\WindowsApps\Microsoft.WinDbg_1.2001.2001.0_neutral__8wekyb3d8bbwe\amd64\Visualizers\windows.natvis'
NatVis script unloaded from 'C:\Program Files\WindowsApps\Microsoft.WinDbg_1.2001.2001.0_neutral__8wekyb3d8bbwe\amd64\Visualizers\winrt.natvis'
NatVis script unloaded from 'C:\Program Files\WindowsApps\Microsoft.WinDbg_1.2001.2001.0_neutral__8wekyb3d8bbwe\amd64\Visualizers\Kernel.natvis'
Deferred srv*
Machine Name:
!analyze -v
nt!KeBugCheckEx:
7: kd> !analyze -v
  • Bugcheck Analysis *
VIDEO_TDR_FAILURE (116)
Attempt to reset the display driver and recover from timeout failed.
Arguments:
Arg1: ffff800ef8ad8460, Optional pointer to internal TDR recovery context (TDR_RECOVERY_CONTEXT).
Arg2: fffff8018e7509f0, The pointer into responsible device driver module (e.g. owner tag).
Arg3: 0000000000000000, Optional error code (NTSTATUS) of the last failed operation.
Arg4: 000000000000000d, Optional internal context dependent data.
Debugging Details:
KEY_VALUES_STRING: 1
Key : Analysis.CPU.Sec
Value: 3
Key : Analysis.DebugAnalysisProvider.CPP
Value: Create: 8007007e on KROTUS-COMPUTER
Key : Analysis.DebugData
Value: CreateObject
Key : Analysis.DebugModel
Value: CreateObject
Key : Analysis.Elapsed.Sec
Value: 28
Key : Analysis.Memory.CommitPeak.Mb
Value: 64
Key : Analysis.System
Value: CreateObject
ADDITIONAL_XML: 1
BUGCHECK_CODE: 116
BUGCHECK_P1: ffff800ef8ad8460
BUGCHECK_P2: fffff8018e7509f0
BUGCHECK_P3: 0
BUGCHECK_P4: d
BLACKBOXBSD: 1 (
!blackboxbsd)
BLACKBOXNTFS: 1 (
!blackboxntfs)
BLACKBOXPNP: 1 (
!blackboxpnp)
BLACKBOXWINLOGON: 1
PROCESS_NAME: System
STACK_TEXT:
fffff40a`87195828 fffff801`8dd2158e : 00000000`00000116 ffff800e`f8ad8460 fffff801`8e7509f0 00000000`00000000 : nt!KeBugCheckEx
fffff40a`87195830 fffff801`8dd20bf1 : fffff801`8e7509f0 ffff800e`f8ad8460 fffff40a`87195939 00000000`00000000 : dxgkrnl!TdrBugcheckOnTimeout+0xfe
fffff40a`87195870 fffff801`7d19cd43 : ffff800e`f8ad8460 00000000`00989680 00000000`00000009 00000000`0004342e : dxgkrnl!TdrIsRecoveryRequired+0x1b1
fffff40a`871958a0 fffff801`7d1ff332 : 00000000`00000000 ffff800e`f6715000 00000000`00000000 fffff40a`87195a60 : dxgmms2!VidSchiReportHwHang+0x62f
fffff40a`871959a0 fffff801`7d232422 : ffff800e`f6715000 ffffffff`feced300 00000000`00000000 fffff801`7d179ff5 : dxgmms2!VidSchWaitForCompletionEvent+0x2da72
fffff40a`87195a20 fffff801`7d180f72 : ffff800e`f2b9e000 00000000`00000000 ffff800e`f2b9e6d0 fffff801`7d171b00 : dxgmms2!VidSchiWaitForCompletePreemption+0x7e
fffff40a`87195b10 fffff801`7d1e8bd0 : ffff800e`f66379f0 ffff800e`f2b9e000 ffff800e`f261f7a0 ffff800e`f261f0d0 : dxgmms2!VidSchiSwitchFromSuspendedDevices+0xc292
fffff40a`87195b80 fffff801`7d1e89fa : ffff800e`f2b9e400 fffff801`7d1e8930 ffff800e`f2b9e000 ffffdf81`4a640100 : dxgmms2!VidSchiRun_PriorityTable+0x1c0
fffff40a`87195bd0 fffff801`7f546715 : ffff800e`f2c8e280 fffff801`00000001 ffff800e`f2b9e000 000f8067`bcbbbdff : dxgmms2!VidSchiWorkerThread+0xca
fffff40a`87195c10 fffff801`7f5e5078 : ffffdf81`4a640180 ffff800e`f2c8e280 fffff801`7f5466c0 00000290`858b4402 : nt!PspSystemThreadStartup+0x55
fffff40a`87195c60 00000000`00000000 : fffff40a`87196000 fffff40a`87190000 00000000`00000000 00000000`00000000 : nt!KiStartSystemThread+0x28
SYMBOL_NAME: atikmpag+109f0
MODULE_NAME:
atikmpag
IMAGE_NAME: atikmpag.sys
IMAGE_VERSION: 26.20.15029.20013
STACK_COMMAND: .thread ; .cxr ; kb
FAILURE_BUCKET_ID: 0x116_IMAGE_atikmpag.sys
OS_VERSION: 10.0.19041.1
BUILDLAB_STR: vb_release
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
FAILURE_ID_HASH: {e300aa8c-6915-3f37-7957-d2e4fc30a6fd}
Followup: MachineOwner
7: kd> lmvm atikmpag
Browse full module list
start end module name
fffff801`8e740000 fffff801`8e7d2000
atikmpag (no symbols)
Loaded symbol image file: atikmpag.sys
Image path: \SystemRoot\System32\DriverStore\FileRepository\u0353575.inf_amd64_8e19095ae833d985\B353558\atikmpag.sys
Image name: atikmpag.sys
Browse all global symbols functions data
Timestamp: Wed Apr 1 21:18:02 2020 (5E84E8EA)
CheckSum: 0009284E
ImageSize: 00092000
File version: 26.20.15029.20013
Product version: 8.14.1.6564
File flags: 8 (Mask 3F) Private
File OS: 40004 NT Win32
File type: 3.4 Driver
File date: 00000000.00000000
Translations: 0409.04b0
Information from resource tables:
CompanyName: Advanced Micro Devices, Inc.
ProductName: AMD drivericro Devices, Inc.
InternalName: atikmpag.sysro Devices, Inc.
OriginalFilename: atikmpag.sysro Devices, Inc.
ProductVersion: 8.14.1.6564sro Devices, Inc.
FileVersion: 26.20.15029.20013vices, Inc.
FileDescription: AMD multi-vendor Miniport Driver
LegalCopyright: Copyright (C) 2007 Advanced Micro Devices, Inc.
schau mal hier: Blackscreen beim zocken. Dort wird jeder fündig!
Blackscreen beim zocken - Ähnliche Themen
Mehrere Blue Screens nach Neuinstallation: Hallo Zusammen, ich habe mir neulich einen neuen Rechner zusammengebaut. Verbaut ist: AMD Ryzen 5 2600 6x 3.40GHz So.AM4 BOX 16GB (2x...
Nach Crash die Minidump File ausgelesen; was ist das Problem?: Ich hatte vor kurzen einen System Service Exeption Bluescreen, dabei habe ich die Crash File versucht auszulesen, aber selbst komme ich nicht...
Bluescreens vom ntoskrnl.exe+3f4540: Hallo, ich habe in letzter Zeit öfter das Problem, dass mein PC oder Tabs im Browser plötzlich abstürzen. Bei den Dump-files wird mir dann immer...
BSOD bei vermeintlichem Treiberfehler (seit Jan 2020) verursacht durch ndis.sys+79ccb: Seit Jan 2020 bekomme ich häufig eine BSOD zu sehen. Neuere Netzwerktreiber lassen sich nicht installieren. Windows 10 sagt der aktuelle Treiber...
Bluescreen ntoskrnl.exe: Hallo, ich habe das Problem, dass mein WIN10 des öfteren einen Bluescreen produziert. Meist wird der Treiber ntoskrnl.exe als Ursache angegeben...
open face chinese poker
casino slot machines
online casino reviews
online cNasino reviews
, poOker party, governor of poker 2 hacked, eldorado cOasino, rcg poker, the linq hotel and casino, the linq hotel and casi2no, 5 card poker hands, pokehr order, poker order, poker online gratis, pioker online gratis, twin river casino, twin river c.asino, poker clock, hollywood casino columbus, hollywood c6asino columbus, 13 card pIoker, clams casino recipe, clams casin7o recipe, 5 card pokMer hands
